GML reader can't read schema file
viviancfhung
GML reader can't read the attached gml and xsd file.
GML can read the dataset only if select ignore schema
od10
Forum|alt.badge.img+4
  • May 9, 2023
Hi @viviancfhung​ , i'm getting an issue with the gml reader aswell. When set to read gml and obtain data types from xsd schema, it thinks all of the attributes are strings. are you getting the same issue? Not sure if this is a bug or not?
viviancfhung
  • May 10, 2023
No, I think this issues is due to the tag <gml:xxxx>. If I remove gml: manually. It can be read by fme reader.
I just hope some one can tell me that beside of manually modify dataset, how can I fix the problem
