How does FME Server get its values for Shared folders for transformers
  • September 12, 2019
  • 7 views
helmoet
Forum|alt.badge.img+8
When a job is run on our FME Server system, I see this list of shared folders for formats, transformers, coordinate systems and coordinate system exceptions:
How does FME Server determine these folders? Which user is used? Does it depend on any user logged in onto the server? Is it documented somewhere?
Thankx for any answer.
erik_jan
Forum|alt.badge.img+17
Hi @helmoet,
It is listed in the FMEServerConfig.txt file under:
# Shared Resource Management
Hope this helps,
Erik Jan
helmoet
  • September 19, 2019
Hi @erik_jan, Thanks for responding, we picked up a signal that these values would depend on any user logged on to the windows server, hence the question. however, that seems impossible regarding this anwer.
