Add attribute to parcels from irregular area overlay
I have a layer that is of scenic hillsides and I need to add an attribute indicating that to the parcels that are touched by the area. When I used the AreaonAreaOverlayer, it clipped the parcels to match the scenic hillside area. I need a way to add an attribute to the required parcels without changing their shape.
Rich Text Editor, editor1
Editor toolbars
Press ALT 0 for help
