The Geodatabase is newer than the ArcGIS installed on this machine
  • November 16, 2022
  • 29 views
I'm trying to run an old project in Desktop 2020 and keep running up against the error "The Geodatabase ... is newer than the ArcGIS installed on this machine. As a result the Geodatabase cannot be opened"
Log file shows it checks out a license from ArcGIS 10.6.1 but I have ArcGIS 10.8 installed, although there is a Desktop10.6 folder in ArcGIS/Program files as well.
Can I 'force' FME to select a 10.8 ArcGIS license or is there another work around?
  • November 16, 2022
@steve-h​ In FME 2022 there is an option to select ArcMap or ArcGIS Pro under the Workbench navigation tree, Workspace Parameters, Translation, Esri ArcGIS Compatibility. I don't think this will help you in this case. I think it's more likely that this Geodatabase has been edited in ArcGIS Pro and is no longer compatible with ArcGIS Desktop
