I converted FME server DB from default to Oracle in FME server 2017.0.1.1. Due to a notification bug in this version, I am upgrading to the latest 2017.1. I am wondering if I still need to do the restore from the backup. I would think I just need to back up the config files, particularly
fmeCommonConfig.txt, uninstall 2017.0.1.1, install 2017.1, change Database connection in
fmeCommonConfig.txt, restart the server/core/db, everything will just magically work fine. Is this correct?
