ArcSDE to SQLite
Hi!
I have a problem with a transformation from an ArcSDE-database to a SQLite-database. When I go from the ArcSDE-database to shapefiles it is about 10 times faster compared  to if I go to the SQLite-database.
I have WRITER MODE: INSERT and I want to overwrite the database.
I am using FME2013 Esri edition.
  • October 3, 2013
which SQLite writer are you using? There are 3:
SQLite non-spatial
SQLite spatial (FDO)
SpatiaLite
If you need geometries, consider trying the SpatiaLite writer.
David
  • October 4, 2013
Hi David and thanks for the quick response.
I am using SQLite spatial (FDO). I've tried the SpatiaLite with good result, but I cant connect my SQLite-database in Autocad Map.
//Johan
  • October 7, 2013
It is unfortunately the nature of the beast; a proper database implementation will almost always have worse performance than a Shapefile.
I believe FDO is a middle layer (a bit like ArcSDE) and it might also slow things down a little bit.
Make sure that you're writing to a local directory and not a network share.
Also check if you've defined an index on one or more columns, if so try to disable them and see if it improves the write speed.
David
