FME Server web interface url
clang
We've just upgraded FME server from 2016 to 2017. The restore has been successful and all repositories and schedules are currently up and running with the exception of those workbenches where the FMEServerJobSubmitter transformer is embedded. They are failing because the FME Server web url has been modified during the upgrade procedure and now requires the port number to be suffixed to the url, for example
should be - http://scnfme.mycounil.gov
currently - http://scnfme.mycouncil.gov:8080
How can the port number be removed from the url? I have modified the url settings in services to no avail.
Thanks in advance,
Chris
Best answer by david_r
If you don't want the port number to appear in the URL, you'll have to change the port number to the default, which is 80 for http (unsecured) connections. Obviously, this port cannot be in use by any other applications on your server.
Here's the instructions for changing the port number on FME Server: https://docs.safe.com/fme/html/FME_Server_Documentation/Content/AdminGuide/Changing-Web-App-Server-Host-Name-Port.htm
  • January 4, 2018
clang
  • January 4, 2018
That worked, thank you.
