HIDE_EXTERNAL_CONTENT in Kubernetes not working
I am attempting to hide external user content in FME server (FME Server 2020.0.2.1, Build 20238 - linux-x64) deployed to Openshift using the safe provided helm charts and docker images (With some minor modifications).
I have updated the docker images to apply the same change as described in the linked article by updating the relevent confd template. I have verified the file `/usr/local/tomcat/webapps/fmeserver/WEB-INF/conf$ file propertiesFile.properties` in the web container of the core pod is updated.
/usr/local/tomcat/webapps/fmeserver/WEB-INF/confgrep EXTERNAL_CONTENT propertiesFile.properties
# HIDE_EXTERNAL_CONTENT - Disable all external content from being displayed in the WebUI
HIDE_EXTERNAL_CONTENT=true
This appears to be the correct file based on the document and I cannot find any other references to this term but I am not seeing any change to the WebUI and the links to safe.com are still available.
Does anyone have any idea what the issue might be?
Hi @nokout​
Unfortunately it looks like a bug that the links to external content do still work. I believe the flag does still impact external content/links available on the log in page.
We haven't had any reports from customers in a long time relating to this feature so we were planning to remove this flag in the future. Please let me know if this is critical for you and I can make a note on our issue that's requesting the removal to see whether we can fix it instead.
  • January 24, 2021
Thanks for the information.
I was pursuing it because it was picked up in our organisation's security assessment. I suspect mostly because it is highlighted in the "Securing FME Server" document. I will review with them but I dont think any action is required now but it updating the documentation when a decision is made on the feature would be great.
