BackupConfiguration.fmw "Unable to retrieve backup from FME Server..."
benvk
Forum|alt.badge.img+7
Hi all, I have done some searching for a solution but I have come up empty handed thus far, I am hoping someone can assist.
I am running the stock standard backupConfiguration.fmw that comes out of the box with FME Server, but each time I try to run it, I am getting the below error:
60	2022-6-15 08:03:49 | HTTPCaller (HTTPFactory): An error occurred while accessing the URL 'https://PANDORA:443/fmerest/v3/migration/backup/download'
61	2022-6-15 08:03:49 | The below feature caused the translation to be terminated
83	2022-6-15 08:03:49 | Terminator (TestFactory): Terminator: Termination Message: 'Unable to retrieve backup from FME Server `https://PANDORA:443' Please ensure that the credentials are correct and that user `benva' has fmesuperuser role. The error was: HTTP/1.1 401.'
84	2022-6-15 08:03:49 | HTTPCaller (HTTPFactory): Termination Message: '%0'
85	2022-6-15 08:03:49 | Creator_XML_Creator (CreationFactory): Terminator: Termination Message: 'Unable to retrieve backup from FME Server `https://PANDORA:443' Please ensure that the credentials are correct and that user `benva' has fmesuperuser role. The error was: HTTP/1.1 401.'
I have now confirmed that the user benva is fmesuperuser:
benva user management screen
And then I have confirmed that we have not made any changes to the superuser role, this still has access to 'all permissions':
fmesuperuser role
I then open the workspace on the server and run it manually (i enter my username and password) and it works fine.
run manually
But opening the scheduled task, entering username/password and pressing 'trigger' it fails....
I am stumped as to what else I can check, the log seems to only indicate that the role is the issue....
Any thoughts/ideas?
Log file attached
Best answer by richardatsafe
Hi @benvk​ ,
Unfortunately, this looks like a bug where the password parameter might not be picked up correctly, which I will have fixed. In the mean-time would you be able to confirm that creating a new schedule that runs the backupConfiguration.fmw works? Thank you for letting us know about this issue.
richardatsafe
Forum|alt.badge.img+10
  • June 16, 2022
Hi @benvk​ ,
benvk
  • October 21, 2022
richardatsafe wrote:
Hi @benvk​ ,
Sorry @richardatsafe​ I just logged in and realised I never responded to your question!
I can confirm creating a new schedule did allow the workspace to run without issue.
Thank you for your help.
This worked for me too
Thanks
let us know when the bug is fixed
richardatsafe
Hi @stevetaylor​ ,
This is fixed in FME Server 2022.0 onwards.
