Add AHD and ellipsoid CRS to las files
  • December 20, 2022
  • 15 views
I'm trying to do two things.
Firstly, trying to add GDA 2020 zone 56 Australian Height Datum (AHD) to las files that currently have no projection.
Second, trying to add GDA 2020 zone 56 ellipsoid (GRS 1980) height to las files that currently have no projection.
I'm able to reproject each las files using the reprojector functions, but this is for the horizontal coordinate systems not vertical height.
Is there a way to add AHD and ellipsoid heights to the las files within FME?
Thank you for your time
nielsgerrits
Not an expert in this field, but you might be looking for the PROJReprojector.
