Released
Allows the user to save multiple settings and can set each name.
Related products:FME Form
  • July 9, 2016
  • 2 views
  • rylanatsafe
    rylanatsafe
  • siennaatsafe
    siennaatsafe
  • jdh
    jdh
  • kam
  • taojunabc
    taojunabc
taojunabc
Participant
The current FME(2016.1.0.1) only allow the user to save one setting. But many times we need to switch between in many Settings, I hope I can save multiple setting, and can be set each name.
debbiatsafe
Forum|alt.badge.img+20
This idea has been implemented for FME Desktop 2019 as presets--users now have the ability to save, load, and set default parameter presets for transformers, readers, or writers. Presets allow you to save and name your own sets of parameter values so you can easily use them again and override the FME default values.
