With Desktop 2013, is anyone familiar with a workflow I can use within FME to populate two attribute fields (in a stormwater pipes layer), with corresponding IDs from a connected stormwater pits layer which is snapped to the start and end of each pipe.
The pipe layer is digitised in direction of flow so I would be looking to populate the corresponding upstream and downstream pit attributes to reflect this.
Note: ESRI used to have a VB Script which did this but it is no longer supported in 10.1.
thanks!!!
