FME Form 2023.2 installed produce a memory Error at startup : "The instruction at 0x00007FFC9A16C1D0 referenced memory at 0xFFFFFFFFFFFFFFFF. The memory could not be read."
p-chessel-vdg
Forum|alt.badge.img+4
FME Form 2023.2 installed produce always a memory Error at startup : "The instruction at 0x00007FFC9A16C1D0 referenced memory at 0xFFFFFFFFFFFFFFFF. The memory could not be read."
Click OK to terminate the program.
The environnement is VMWARE Windows Server 2019 Datacenter, 16GB RAM, 4 CPU.
This same machine runs FME 2020.1 32bits and 64bits with no issues.
I have désinstalled ,reboot, reinstalled the FME product , same issue.
If this is a know issue , is there a configuration to change ?
How to troubleshoot ?
Thanks
p-chessel-vdg
  • January 16, 2024
If i go into Event Viewer , I can see an Application Error corresponding to crash
Faulting application name: fmeworkbench.exe, version: 2023.7.48.23774, time stamp: 0x65977a01
Faulting module name: Qt6Widgets_fme.dll, version: 6.5.1.0, time stamp: 0x6516ff90
Exception code: 0xc0000005
Fault offset: 0x000000000037c1d0
Faulting process id: 0x1d44
Faulting application start time: 0x01da488fccd2fcfa
Faulting application path: C:\\apps\\FME2023\\fmeworkbench.exe
Faulting module path: C:\\apps\\FME2023\\Qt6Widgets_fme.dll
Report Id: d22a0fdd-d2e1-43ef-9ad4-f3de35f19088
Faulting package full name:
Faulting package-relative application ID:
p-chessel-vdg
  • January 16, 2024
