I wanted to convert thatches from AutoCAD to polygons. All worked fine except one polygon which is converted incorrectly (not as is in AutoCAD)
The CAD file can be found in the link below:
http://www.mediafire.com/download/s8ests0hxasklpo/DierAlGosoun_Tulkarm_UrbanMasterPlan_Hatches.dwg
What might be the issue here?
Thank you
Best
Jamal
