Hello,
Our AV policy is set so that any unknown executable file is blocked unless it is trusted. There are two options for a file to get into this state:
1) The file is signed by a recognized Certification Authority
2) It has been analyzed by the AV itself (and it has to be executed prior to analysis)
This means that after every update we have to experience continuous blocks -as every dll is analyzed independently- until the whole program becomes functional.
As a good security practice that any mature software company should perform, could you please sign your code?
Thank you in advanced,
