DWG writing polylines with arcs and lines
zzupljanin
Forum|alt.badge.img+4
I'm having problem writing polylines that consists of arcs and lines in AutoCAD. It seems it only happens when using Reprojector or similar. While writing arc part of polyline gets stroked in AutoCAD.
Does anyone have any idea what am I missing?
Cheers,
Želimir
Best answer by xiaomengatsafe
Hi @zzupljanin, sometimes it is necessary to stroke arcs into lines, during reprojection, to best maintain the shape of the arc. You can try using the ArcEstimator transformer to turn them back into arcs, after reprojection. http://docs.safe.com/fme/2019.0/html/FME_Desktop_Documentation/FME_Transformers/Transformers/arcestimator.htm
Hope this helps.
pratap
Forum|alt.badge.img+11
  • April 8, 2019
Have you tried "LineCombiner"
zzupljanin
  • April 19, 2019
Yes, I did. Still turning arced parts as polylines.
pratap
  • April 22, 2019
Is it addressed or not??
If not... please send some screenshot to understand better
zzupljanin
  • April 23, 2019
OK, here's a workbench and some pictures. As I said, after Reprojector, arced part of polyline gets stroked while writing in AutoCAD.
Before reprojecting:
After reprojecting:
In inspector (right before writing) there's correct definition of polyline with arced part of path:
Workbench:
autocad_path_polyline_test.fmwt
There are three workarounds in fmw using various transformers all giving same result in final AutoCAD file.
PS. I'm using FME 2018.1.
xiaomengatsafe
Forum|alt.badge.img+3
Hope this helps.
zzupljanin
  • April 24, 2019
Hope this helps.
Yes, this idea works.
Doing ArcStroker before Reprojector and then ArcEstimator of arced parts does the trick.
Thank you.
