Current steps
Revit IFC reader
Geometry Coercer -> FME_composite_surface
Surface Footprint Replacer -> Overhead Shadow
Geometry Refiner
Scaler
Dissolver
GDB Writer
Extra info: The process has been created as a result of mostly trial and error with varying IFC files, although mostly similar. For this exercise attribution can be ignored other than FME_feature_type to remove the redundant IFC components (site, project, building etc)
It feels like there is a lot of 'junk' in the IFC format that is not required for geometry work. What steps are possible to clean / optimize / dissolve IFC files or their derivatives to increase workbench processing speed. I cannot supply an example IFC file due to data security.
