Sorting 'date' using sorter with option Alpha/Num does not work Sorting 'dates': Regular sorter on dates( e.g 26/05/2023....) as alpha/num options do not work.Could there be another way to do this date sorting?
  • September 8, 2023
  • 185 views
angwan
Best answer by nielsgerrits
You need to convert the date to fme date first. This can be done using the DateTimeConverter.
nielsgerrits
Forum|alt.badge.img+53
  • September 8, 2023
angwan
  • September 8, 2023
Thanks @nielsgerrits, that works with fme date format(e.g. 20230526). Limited though, if one would like to have a different date format that requires sorting.Cheers.
