Creating multiple 2D MIN/MAX boxes with one creator
  • September 8, 2021
  • 39 views
fmenco
Forum|alt.badge.img+5
As the title says, is it possible to creating multiple 2D Min/Max boxes with one creator? Or do I need to have multiple creators, one for each box/ string of coordinates?
danilo_fme
Forum|alt.badge.img+45
  • September 9, 2021
Hi @fmenco​
For to have multiple box, I sugest you to use the transformer 2DBoxReplacer https://docs.safe.com/fme/2021.1/html/FME_Desktop_Documentation/FME_Transformers/Transformers/2dboxreplacer.htm
Thanks in Advance,
Danilo
Forum|alt.badge.img+49
danilo_fme wrote:
Hi @fmenco​
Thanks in Advance,
Danilo
I agree with @danilo_fme​ , the easiest way would be to create a CSV or Excel file with at least an id and min/max x and y colums and then a 2DBoxReplacer to create the boxes.
