How can I send a notification by mail at the exact moment a table is updated in Oracle?
I want to instantly receive a notification email when a new record has been added to a table that is in Oracle
danilo_fme
Forum|alt.badge.img+41
  • October 11, 2019
Hi @joeroses
I suggest you to use the transformer FeatureWriter to update attributes and after the transformer Emailer.
Thanks,
Danilo
  • October 11, 2019
If the table is updated with something non-FME and it's urgent that you get the notification, one of the better solutions is probably to write an Oracle trigger on that table that can notify FME Server using the REST API, which in turn could send the email.
Maybe it's even possible to send an email directly from an Oracle trigger? Hmmm
https://asktom.oracle.com/pls/apex/f?p=100:11:0::::P11_QUESTION_ID:7267435205059
  • October 11, 2019
danilo_fme wrote:
Hi @joeroses
Thanks,
Danilo
Thanks a lot
danilo_fme
  • October 11, 2019
joeroses wrote:
Thanks a lot
You are welcome :)
  • October 11, 2019
Thank you very much
