Creating published parameters
Can I create a published parameter to accept either a value or an attribute name?
You see this quite a bit in the transformer parameters, where you can either type in a constant value, or select from an attribute list.
Cheers
Keith
Forum|alt.badge.img+21
  • March 26, 2015
Hi Keith,
You can create such a user parameter from a transformer parameters dialog.
Menu button of the parameter > User Parameter > Create User Parameter
For example:
Takashi
  • March 26, 2015
Thanks Takashi,
As it turned out I had created the parameter correctly, as it worked exactly how I wanted it to when running. It was just when I was creating the parameter that I wasn't getting the 'select attribute' option, hence the confusion.
