How to return the JOB ID in a notification from FME server
I would like to know how to get the JOB ID included in a notification I get from FME Server. With lots of job's running each night and I need the job id when I get notified of a failed run. Can someone point me in the right direction?
Best answer by tg
Hi Ben,
If you use the Email Subscriber you can use the keyword {id}.
http://docs.safe.com/fme/html/FME_Server_Documentation/Default.htm#ServerCore/Email_Templates.htm
Thomas
