How to delete entire line items from an excel sheet by the summed up amount field?
  • January 20, 2015
  • 7 views
I need to delete entire lines on an excel spread sheet with over 1 Million line items based on the sum of the amount field. Basically, I have one large spreadsheet with I first need to categorize by department name, then vendor name, and delete the lines of expenditures to each vendor if it does not exceed a certain amount. Is there a way to accomplish this on FME?
Best answer by owen
Hello,
Yes, you could use a testfilter to filter out records over a certain amount, and write the remainder out using a dynamic writer.
Owen
owen
  • January 21, 2015
Hello,
Owen
