Hi everyone and thanks for your time
I've used HullReplacer in order to get my polygon, see attached - but is there a way to place it FLAT at the calculated lowest point of the object.
Thank you
Thank you
Best answer by daveatsafe
Thanks @daveatsafe
I have tried BUT... It's most likely me being an amateur
Please see below:
My overlay is crated based on the TIN from the LAS, When I use Bound Extractor it creates one big for all the objects instead of multiple small ones...
Hi @joolek.o ,
OK, it's a little more complex, but you can try the following process:
