Can I use polyline (.shp file) and convert them to 3d display them with AR(FMEAR) ?
Best answer by nielsgerrits
Yes you can. See Getting Started with Augmented Reality (FME AR)
I think you need to 3d buffer the lines to solids, but the Bufferer can do that nowadays.
