I have a Culvert table with 90K rows. Each culvert belongs to one of 7 size categories. Each category uses a different formula to calculate a culvert's replacement cost. I'm currently using TestFilter to define the size categories. I then route each output to its own ExpressionEvaluator. Is there a way to use a single transformer with a CASE statement to accomplish the same thing?
What's the best way to handle calculations for filtered attributes?
Best answer by courtney_m
You can do this with an AttributeManager (or AttributeCreator for older versions of FME). Type in the name of the new attribute you want to create - then click on the drop-down arrow on that line, and select Conditional Value:
In the conditional value dialog, you can set up your conditional statements like you did in your TestFilter. But you can specify an output value for each statement. See the screenshot below on how to use the Arithmetic Editor to calculate the value for each statement:
Rich Text Editor, editor1
Editor toolbars
Press ALT 0 for help
