Archived
Expose FME Server host name in FMEServerJobSubmitter result feature
Related products:Transformers
siennaatsafe
nic_ran
ronan
jeroen
mtaftferguson
+2
  • siennaatsafe
    siennaatsafe
  • nic_ran
    nic_ran
  • ronan
    ronan
  • jeroen
    jeroen
  • mtaftferguson
    mtaftferguson
  • tnarladni
    tnarladni
  • laurawatsafe
    laurawatsafe
nic_ran
It is sometimes necessary to notify external applications of the server name (host name) on which an FME Server job has been submitted. This can be useful, for example, for the external application to monitor the status of a submitted job to determine when the job has completed.
The FME Server host name for a submitted job is not available anywhere via workbench. (The FME Server host name is available for the currently running job but this is not necessarily the same as the Server a job has been submitted to.)
It would be great if the FME Server host name could be made available on all 3 output ports of the FMEServerJobSubmitter (Submitted, Summary, <Rejected>).
See also this question for further details:
https://knowledge.safe.com/questions/73769/exposing-web-connection-details-in-workspace.html
