SharePoint Online List Writer error - Python Exception <TypeError>: unhashable type: 'dict'
  • April 20, 2022
  • 45 views
Up until 4/12, my workspace was writing to a SP list normally. It reads data from SQL and updates the SP list to match any changes. After someone changed the name of a SP column on the 12th, the workflow errored - but after the change was reverted, it still errored. The first line with the Python Exception was not in the original error when the column name was changed:
Python Exception <TypeError>: unhashable type'dict'
SHAREPOINT writer: A fatal error has occurred. Check the logfile above for details
FeatureJoiner_2_JOINED_-1_35_Player (RecorderFactory): SHAREPOINT writer: A fatal error has occurred. Check the logfile above for details
First photo is an overview of the workspace - everything runs fine up until the SharePoint Writer labeled "TOPS Project List". No problems with the SharePoint Reader. Second photo is settings for the Writer (which worked fine last week!).
fme1
fme2
e.degraaff
Same problem. Is there still no solution?
