How to look in specific attribute for specific values from other attribute ?
gogopotter90
Forum|alt.badge.img+13
Hello ,
i habe two source data
first source data contains attribute called
id
3839464
3937793
837390
389304
second source data contains
cable network attribute
3839464-hsld282-owuwpw
37394-283994
383894-Jagdhorn-2839463
389304-hdjskd-dddjf
how could I search at attribute cable network
by using id attribute ?
i would like to know if any of id value exist in cable network attribute .
fme 2021
thanks in advance
todd_davis
Forum|alt.badge.img+21
  • December 5, 2023
Can you get to 2023? If you can, then I have an answer. You really need 2023 as it contains a bug fix which allowed me to add some functionality to the AttributeValueSearcher that caters for this scenario.
todd_davis
  • December 5, 2023
Actually, as you are only searching one field, then you can do it with ease...without the above. Use the same method through to the featurejoiner and following the featurejoiner use a Tester, and test the "cable network contains id" (of course that is pretty wild in it selection with an id of 1 being found in any cable network value that contains 1, so you may need to add in some extra logic). That will return all the values in the cable network that match
dustin
Forum|alt.badge.img+30
  • December 5, 2023
There is a custom transformer located in FME Hub called FuzzyStringCompareFrom2Datasets. I'm not positive it will give the expected result in this scenario, but it may be worth a shot. https://hub.safe.com/publishers/cdalessandro/transformers/fuzzystringcomparefrom2datasets
  • December 5, 2023
Hi @gogopotter90​ ,
Looks like a cable network can be split by hyphen into two or more parts and the first part is always id. If my observation is correct, you can just split it with AttributeSplitter and then use ListIndexer (List Index to Copy: 0) to extrat the first part i.e. id.
gogopotter90
  • December 7, 2023
takashi wrote:
Hi @gogopotter90​ ,
It is not always the first part .
i am not sure which part does it .
gogopotter90
  • December 7, 2023
It takes too long time to get output ,i have tried it
gogopotter90
  • December 7, 2023
I have only Fme 2021 .
But it is not clear what should I do ,after feature joined but it looks too much data to join between left and right .
but anyway what should I do after tester .
do you have other method could I apply without taking too much time
geomancer
Forum|alt.badge.img+47
  • December 7, 2023
If the value of 'id' can be in any part of 'cable network', do something like this (based on the workflow presented by todd_davis):
