assigning distance values to line segment lengths
Hi hope someone can help me.
To simplify, I have a line that is 500 meters long.  As part of its attibutes it has a attribute called 'Start Chainage' of 0 and an attribute called 'end chainage' of 500.
In FME I have used snipper to cut the line into lengths of 20 meters.
What I need is to give each one of those segments their own sequential start and end chanages.
So the first segment will have a start chainage of 0 and an end chainage of 20, the next segment will have a start chainage of 20 and end chainage of 40 and so on.....
The reason for this is so that I can identify at what point (chainage) along the road some other feature crosses or intesects it.
Thanks in Advance.
  • January 7, 2014
take a look at the Linear Referencing transformers in FME.
One possible solution might be to first use a MeasureGenerator on the 500m line, then the Snipper to cut it into 20m segment, then the MeasureExtractor to get the M-values (or chainages, as you call them) at the start and end of each segment.
David
Forum|alt.badge.img+19
  • January 7, 2014
Hi Torro,
I think the solution depends on how to divide original 500m line into 20m segments. If you applied "Cloner and Snipper" method discussed in the previous thread - Road Chainage, every segment has "_copynum" attribute (0-based sequential number), which indicates the snipping order from the start point of the original line. So, you can use it to calculate start / end chainage value. i.e. start = _copynum * 20, end = start + 20.   Sorry, I didn't look at your latest post in the previous thread. But I assume you divided the original line with the "Cloner and Snipper" method successfully.
Takashi
  • January 9, 2014
Hi Takashi/David,
yes the cloner and snipper method worked well but im not sure how to get the start and end length of the line segments using MeasureExtractor.
What should I use as the Type: ?
  • January 9, 2014
Hi Takashi,
what transformer would you recommend to place the expression
(_copynum * 20, end = start + 20) to populate the attributes, Start and End Chainage?
  • January 9, 2014
Hi Takashi,
its all good, used ExprssionEvaluator and all is worked ok.
Cheers,
Torro
