Determine whether a shapefile has a Z and/or M
regie_alam
Participant
What would be the best way (aside from opening the file in a GIS software) to find out if the vertices in a shapefile has a Z and/or an M?
danilo_fme
Forum|alt.badge.img+41
  • May 30, 2024
Hi @regie_alam
I suggest you to use the transformer to identify the coordinates x,y and z - CoordinateExtractor.
And after to filter the Z values:
jkr_wrk
Forum|alt.badge.img+28
  • May 30, 2024
For measures I don't know. Still figuring out how it works.
Forum|alt.badge.img+48
Alternative approach to @danilo_fme and @jkr_wrk excellent suggestions:
You can use the DimensionExtractor transformer to extract the dimension of features (either 2 or 3) to an attribute and then test for that. Then a MeasureExtractor can be used to extract measures. If there are no measures present it will reject those features.
jkr_wrk
  • May 31, 2024
I tried the MeasureExtractor and indeed it rejected my features. But didn't know if it was because it hadn't any or that I didn't search for the right name.
As for dimensions, don't want to brag, but my solution does not require extracting and removing an attribute. Someone at @redgeographics pointed me to that.
