It would be great if the FME workbench could reveal the under lying code for Mapnik and let you adjust certain parameters through code as well as parameters. Or better still allow for a code box that can render images through mapnik code. THere are also a number of other programming laungages that have very useful open sourced libraries that would be brilliant to utulize in FE.
