Checking data between two datasets
  • August 21, 2023
  • 6 views
I have this table of data (as an example)
imageI will be receiving data for each object, and I want to cross check that every attribute (column) that has Yes is provided in the dataset.
Please could someone advise me how to go about doing this and which transformers I should be focussing on?
I was trying to maybe create a list for each object (but failing at the moment) so am a little stuck.
Thank you in advance!
danilo_fme
Forum|alt.badge.img+41
  • August 22, 2023
Hi @celita​
Please, let me check if I did understand you.
I simulate to create a Workspace using two transformers - as you can see:
Excel
Attached the Workspace.
Thanks in Advance,
Danilo
