fme not opening after entering R path
gio
Forum|alt.badge.img+15
Hi All,
Workbench, Inspector etc. do not open after I entered the R path in the path location option.
It did work neatly (the path and all are valid, though not using the default plug-in path), until I shut down the application. When trying to (re)start it gets as far as the splash screen for loading GUI. Then it just pops away.
Event Viewer says:
Faulting application name: fmeworkbench.exe, version: 2018.7.34.18301, time stamp: 0x5ad2626a
Faulting module name: unknown, version: 0.0.0.0, time stamp: 0x00000000
Exception code: 0xc0000005
Fault offset: 0x0000000000000000
Faulting process id: 0xce0
Faulting application path: D:\\PROG\\FME\\fmeworkbench.exe
Faulting module path: unknown
Faulting package full name:
Faulting package-relative application ID:
Does anyone know how to solve this?
Can I somehow reset the location (mind you I can't open the workbench, using certain user profiles)
Can I access the settings file to do so?
xiaomengatsafe
Forum|alt.badge.img+3
This sounds like a bug to me. We'll try to reproduce the problem, and keep you updated. Thanks @gio for bringing this to our attention.
xiaomengatsafe
Hi @gio, Looks like this issue will need some further investigation. We haven't been able to reproduce the problem yet. Would you mind file a Problem Report with the following information, to help us debug this further?
  • The workspace you were running before you shut down FME
  • The custom path you set to R
  • R version
  • a screenshot of the error you get (if any), when trying to launch Workbench
Thank you @gio!
gio
  • July 24, 2018
somehow it is linked to user profiles.
Some conflict in the profile must cause the crash. And it occurred when entering the R path and saving the settings.
Login in with a corrupted profile and starting fme as "different" user starts fme normally.
We are still looking for a solution.
De-installing R and fme and reinstalling just FME does not relieve the problem...alas.
