Ways to use writer as reader.
Is there any possibility on using writer feature that has been generated into reader feature so I can avoid from running the workbench twice?
Best answer by david_r
You can use a FeatureWriter immediately followed by a FeatureReader.
  • October 1, 2020
bwn
Forum|alt.badge.img+26
  • October 1, 2020
Exactly: You can use the "Summary" port of a FeatureWriter as the "Initiator" Input Feature of a FeatureReader. One of the main functions of those Transformers is to Read and Write on the condition of something else happening first before they are triggered.
@david_r​  Thank you so much for your reply... This totally and it works well with my task.. Cheers!!
I have tried this and it works.. Many thanks
