Is it possible to install a package (BIM360connector) to a shared folder instead of the user profile?
bbo
Forum|alt.badge.img+3
I would like to install the transformer AutodeskBIM360DocsConnector o a shared folder instead of an user profiel. That way the transformer can be used by all employees without having to install it in every profile. As we work in Citrix the package is not installed completely and needs to be finished manually for each profile.
Best answer by debbiatsafe
Hello @bbo
Unfortunately, it is not currently possible to install FME packages to a shared folder location.
I would recommend voting on this Ideas page about shared FME package path if this functionality is something you want to see implemented in a future version of FME.
debbiatsafe
Forum|alt.badge.img+20
  • November 8, 2022
Hello @bbo
bbo
  • November 8, 2022
debbiatsafe wrote:
Hello @bbo
Thank you, I just did.
