Hi, I'm trying to write mesh files incl textures from obj to Esri SLPK format. The problem I face it is takes a really long time. I'm a newbie on the slpk format and don't know if there is a smarter way to do the translation. Any help highly apprecia
chrisgrandin
Hi, I'm trying to write mesh files incl textures from obj to Esri SLPK format. The problem I face it is takes a really long time. I'm a newbie on the slpk format and don't know if there is a smarter way to do the translation. Any help highly appreciated.
JennaKAtSafe
Hi @chrisgrandin​ . Could you give more details into your workflow? Sharing a workspace, screenshot, a snippet of a log would help us to help you find a smarter way 🙂
chrisgrandin
  • March 23, 2022
Hi Jenna, Thanks for your answer. I try to provide some more details, please let me know if additional info is needed. I attached the workspace I used and a couple of logfiles. For log_20220323 an output file was written after 9 minutes. But when I try on a larger obj-file the processing goes very very slow. Log_20220323_2 is after several hours and it still is not finished. BR Christofer Christofer Grandin Specialist Geosystems division Hexagon M: +46 (0)70 1406868 E: christofer.grandin@hexagon.com
JennaKAtSafe
Hi Christofer, I wasn't able to find your log attached. Did you attach it to an email thread somewhere?
chrisgrandin
  • March 25, 2022
Hi Jenna, I answerd via mail and attached them there, I'll try on the site instead. I attached the log of the run that took 5+ hours. Still a quite small obj-file.
