Indexing chopped line segments
alfons
Forum|alt.badge.img+7
Hello,
for calculations on line segments I divide a line into its individual segments between two vertices (2-point line) using the transformer "Chopper". For a further processing step I need the number of the segment within the total line. This means that if my line consists of 11 vertices, I have 10 line segments. The first line segment should start with the element ID 0. I have tried to do this with a counter, but without success. For this reason, I would like to ask how I can solve this elegantly. Thanks a lot
Best answer by DanAtSafe
alfons wrote:
it counts all line segments of all lines and dont start a new counting by a new line
You'll need to set the Count Scope to Local and check Group Processing; then Group By the unique line attribute value.
DanAtSafe
Forum|alt.badge.img+17
  • November 1, 2022
@alfons​ What problem are you getting with the Counter?
alfons
  • November 1, 2022
DanAtSafe
  • November 1, 2022
alfons
  • November 2, 2022
to switch the count scope to "local" was the the advice. Thanks a lot, now it runs perfectly
