Trying to create KML Network Links
akipin
I have a workbench to read a bunch of large KMZs which I create a surrounding polygon with some attributes and write out to one master KMZ. What I want to have in each output feature is a Network Link to the detailed original KMZ but cannot figure out how to do this.
I saw in an FME tutorial, Optimizing Large Datasets for KML and Google Earth, where they created Network Links by setting the output feature type to NetworkLink and populated kml_link_href and kml_link_name which I was able to do but all it did was read the referenced KMZ and put all of it's elements into my output KMZ which seems to defeat the purpose of a Network Link being a user clickable link.
Is it possible in FME to create a clickable link in my output KMZ that would open the referenced KMZ ?
