Sharepoint Online 403 Error
johnt
Forum|alt.badge.img+11
So we had a sharepoint list reader working in 2017.0.1.1 on a local machine and from within a VM in Azure. We had to get the VM set up to allow the authentication to work, but it all worked in the end. Recently, upon coming back to this bit of work, we are getting 403 errors in both environments when trying to load the table list. I even tried off work network with 2017.1.2.0 and also get the 403 Error.
We have people looking into it, but wondered if anyone else was experiencing issues, whether this could be a Microsoft patch issue for SharePoint Online, or if anyone knew how to resolve it? It could be a work configuration issue too, so will report back if anyone finds anything.
Kind regards, John
carsonlam
  • April 6, 2018
SharePoint Online's authentication changed recently, which broke how our reader and writer authenticated with it. We've made a fix in FME 2018.0 18291+ and FME 2018.1 betas 18449+.
johnt
  • April 6, 2018
Thanks for the info @carsonlam
