Add a specific text as header and footer of text file
arash_hokm
Forum|alt.badge.img+8
Hello FME Community,
I am using a 'StringConcatenator' and a 'Text Writer' to create a text file. I intend to add two separate texts as the header and footer.
Is there a way to add these texts without duplication?
Best answer by nielsgerrits
One way to do this:
  • Sampler to get a single line feature from the data features and use this feature to create the header and the footer features.
  • AttributeCreators on the header, data and footer streams with an attribute "order" with the values 1, 2 or 3.
  • Sorter to sort on the attribute order.
  • Connect to the writer.
nielsgerrits
Forum|alt.badge.img+53
  • October 11, 2023
One way to do this:
arash_hokm
  • October 11, 2023
nielsgerrits wrote:
One way to do this:
@nielsgerrits​ Thank you very much.
It worked.
