writing into Sde geodatabase
Hi Team,
Can you please let me know if FME can write data into SDE geodatabase or not.
I need to automate spatial data creation process.
My sde geodatabase is in Oracle. SDE/ESRI version is 9.3.1, Geometry storage is SDE binary (BLOB) and feature dataset has geometric network.
Please share your expert views and any details which you can provide.
Many Thanks
Manoj
fmelizard
Forum|alt.badge.img+17
  • January 31, 2018
Hi @mojgarg,
Yes - FME supports Personal, File and Enterprise (or SDE) Geodatabases: https://www.safe.com/fme/formats-matrix/#search=sde
As you are using a retired version of ArcSDE, please see:
https://knowledge.safe.com/articles/22886/fme-compatibility-for-retired-esri-software.html
You would need FME 2009 to FME 2014 SP5 to work with ArcSDE 9.3.1
Note that as ArcSDE 9.3.1 is retired, the latest release of FME does not support it. Public documents that contain Esri Product Life Cycle information can be found at: http://support.esri.com/en/content/productlifecycles.
For information about FME version and Esri edition compatibility, please see: https://knowledge.safe.com/articles/1517/notes-on-fme-and-esri-versions-and-compatibility.html
For more information about the reader and writer in FME:
https://knowledge.safe.com/articles/19440/comparison-of-fme-readers-and-writers-for-sde-and.html
If you have access to FME 2009 to FME 2014 SP5, there are some how-to articles about working with geometric networks:
https://knowledge.safe.com/articles/34856/working-with-esri-geometric-networks.html
https://knowledge.safe.com/articles/698/working-with-networks-topology-and-networktransfor.html
  • January 31, 2018
@NatalieAtSafe
Many Thanks
