I have switched from using a custom transformer to a linked custom transformer for the sake of reusability. While there were no errors when I ran it with the local custom transformer, I started encountering an error message randomly after seeing the "Translation was SUCCESSFULLY" message, which reads "Error missing translation." after I changed it to a linked custom transformer.
Here's some additional information that may help:
1) The number of records outputted by the custom transformer in both cases is the same.
2) In both scenarios, they were executed in "Moderate" mode with parallel processing.
3) Debug logs are enabled, and although there are some "BADNEWS" messages, they were present in both cases.
Can anyone provide me with some hints or guidance to resolve this unknown error message?"
Here below is the screen capture for the error message.
