Json API Error
  • February 16, 2023
  • 11 views
Forum|alt.badge.img+5
I'm getting errors while I extracting data from FME API
The Error is
"A JSON syntax error was found at line 21, column 1691
Unexpected non-whitespace characters were found after the JSON text
UniversalReader -- readSchema resulted in 0 schema features being returned
API Link is
40.76.139.235/fmerest/v3/transformations/jobs/id/238492/log?fmetoken=776f34b59676c6271de9b4735a0d13a8ac2acb0a
  • February 16, 2023
The URL above downloads a job log file, it does not contain a JSON document. Is the link perhaps wrong?
  • February 16, 2023
No the link is correct.​ Yes you are right link download the log file is there any wat where I read the log file in fme
  • February 17, 2023
You can use the text file reader to read the log: https://docs.safe.com/fme/html/FME_Desktop_Documentation/FME_ReadersWriters/textline/textline.htm
It'll return one feature per text line, unless you tell it to read the whole file into a single feature.
