Hi, I am trying to get a hyperlink when I click on a point map created by html report generator, using esri leaflet. I attach an image of what I got if I use the same hyperlink I have used in the table (correct hyperlinks). What would be a good approach? Thanks
How can I add a hyperlink on my map in the html report
