Hello , I create un worbench with XLSTProcessor, very simple. There is a "error running trasnlation" when i start it. The log is not usefull to understand the error. Could you hepl me, please ?
 workbench
20210507-safe-fmw
Log contains:
2021-05-07 12:07:41|  0.0| 0.0|INFORM|FME 2020.1.1.1 (20200817 - Build 20614 - WIN64)
2021-05-07 12:07:41|  0.0| 0.0|INFORM|FME_HOME is 'C:\\FME\\FME-2020\\'
2021-05-07 12:07:41|  0.0| 0.0|INFORM|FME Desktop Professional Edition (floating)
2021-05-07 12:07:41|  0.0| 0.0|INFORM|Permanent License.
2021-05-07 12:07:41|  0.0| 0.0|INFORM|Machine host name is: OPTW-2021-0244
2021-05-07 12:07:41|  0.0| 0.0|INFORM|START - ProcessID: 14748, peak process memory usage: 37980 kB, current process memory usage: 37980 kB
2021-05-07 12:07:41|  0.0| 0.0|INFORM|FME Configuration: Command line arguments are `C:\\FME\\FME-2020\\fme.exe' `D:/3-calcul/17-geode4D/geotiff/2-fme\\wb-xlate-1620382050570_14140' `LOG_STANDARDOUT' `YES' `LogCountServerName' `{aca64a6c-290b-4cef-a181-2bf8f5c14a8a}'
2021-05-07 12:07:41|  0.0| 0.0|INFORM|FME Configuration: Connection Storage: 'C:\\Users\\edumont\\AppData\\Roaming\\Safe Software\\FME\\'
2021-05-07 12:07:42|  0.3| 0.2|INFORM|Shared folders for formats are : C:\\FME\\FME-2020\\datasources;C:\\Users\\edumont\\Documents\\FME\\Formats
2021-05-07 12:07:42|  0.3| 0.0|INFORM|Shared folders for transformers are : C:\\Users\\edumont\\AppData\\Roaming\\Safe Software\\FME\\Packages\\20614-win64\\transformers;C:\\FME\\FME-2020\\transformers;M:\\_TOOLS_FME\\Transformers;C:\\Users\\edumont\\AppData\\Roaming\\Safe Software\\FME\\FME Store\\Transformers
2021-05-07 12:07:42|  0.3| 0.0|INFORM|Shared folders for coordinate systems are : C:\\Users\\edumont\\Documents\\FME\\CoordinateSystems
2021-05-07 12:07:42|  0.3| 0.0|INFORM|Shared folders for coordinate system exceptions are : C:\\Users\\edumont\\Documents\\FME\\CoordinateSystemExceptions
2021-05-07 12:07:42|  0.3| 0.0|INFORM|Shared folders for coordinate system grid overrides are : C:\\Users\\edumont\\Documents\\FME\\CoordinateSystemGridOverrides
2021-05-07 12:07:42|  0.3| 0.0|INFORM|Shared folders for CS-MAP transformation exceptions are : C:\\Users\\edumont\\Documents\\FME\\CsmapTransformationExceptions
2021-05-07 12:07:42|  0.3| 0.0|INFORM|Shared folders for transformer categories are : C:\\Users\\edumont\\Documents\\FME\\TransformerCategories
2021-05-07 12:07:42|  0.3| 0.0|INFORM|FME Configuration: Reader Keyword is `MULTI_READER'
2021-05-07 12:07:42|  0.3| 0.0|INFORM|FME Configuration: Writer Keyword is `NULL_DEST'
2021-05-07 12:07:42|  0.3| 0.0|INFORM|FME Configuration: Writer Group Definition Keyword is `NULL_DEST_DEF'
2021-05-07 12:07:42|  0.3| 0.0|INFORM|FME Configuration: Reader type is `MULTI_READER'
2021-05-07 12:07:42|  0.3| 0.0|INFORM|FME Configuration: Writer type is `NULL'
2021-05-07 12:07:42|  0.3| 0.0|INFORM|FME Configuration: No destination coordinate system set
2021-05-07 12:07:42|  0.3| 0.0|INFORM|FME Configuration: Current working folder is `D:\\3-calcul\\17-geode4D\\geotiff\\2-fme'
2021-05-07 12:07:42|  0.3| 0.0|INFORM|FME Configuration: Temporary folder is `C:\\Users\\edumont\\AppData\\Local\\Temp\\wbrun_1620372707449_14140\\fmetmp_1620382050610_14140', set from environment variable `FME_TEMP'
2021-05-07 12:07:42|  0.3| 0.0|INFORM|FME Configuration: FME_HOME is `C:\\FME\\FME-2020\\'
2021-05-07 12:07:42|  0.3| 0.0|INFORM|FME Configuration: FME_BASE is 'no'
2021-05-07 12:07:42|  0.3| 0.0|INFORM|FME Configuration: FME_MF_DIR is 'D:\\3-calcul\\17-geode4D\\geotiff\\2-fme/'
2021-05-07 12:07:42|  0.3| 0.0|INFORM|FME Configuration: FME_MF_NAME is 'transfo.fmw'
2021-05-07 12:07:42|  0.3| 0.0|INFORM|FME Configuration: FME_PRODUCT_NAME is 'FME(R) 2020.1.1.1'
2021-05-07 12:07:42|  0.3| 0.0|INFORM|System Status: 120.93 GB of disk space available in the FME temporary folder (C:\\Users\\edumont\\AppData\\Local\\Temp\\wbrun_1620372707449_14140\\fmetmp_1620382050610_14140)
2021-05-07 12:07:42|  0.3| 0.0|INFORM|System Status: 31.78 GB of physical memory available
2021-05-07 12:07:42|  0.3| 0.0|INFORM|System Status: 127.11 GB of virtual memory available
2021-05-07 12:07:42|  0.3| 0.0|INFORM|Operating System: Microsoft Windows 10 64-bit (Build 18362)
2021-05-07 12:07:42|  0.3| 0.0|INFORM|FME Platform: WIN64
2021-05-07 12:07:42|  0.3| 0.0|INFORM|Locale: fr_FR
2021-05-07 12:07:42|  0.3| 0.0|INFORM|System Encoding: windows-1252
2021-05-07 12:07:42|  0.3| 0.0|INFORM|FME Configuration: Start freeing memory when the process exceeds 95.34 GB
2021-05-07 12:07:42|  0.3| 0.0|INFORM|FME Configuration: Stop freeing memory when the process is below 71.50 GB
2021-05-07 12:07:43|  0.3| 0.0|INFORM|Creating writer for format: NULL (Nothing)
2021-05-07 12:07:43|  0.3| 0.0|INFORM|Trying to find a DYNAMIC plugin for writer named `NULL'
2021-05-07 12:07:43|  0.3| 0.0|INFORM|Loaded module 'NULL' from file 'C:\\FME\\FME-2020\\plugins/NULL.dll'
2021-05-07 12:07:43|  0.3| 0.0|INFORM|FME API version of module 'NULL' matches current internal version (3.8 20200115)
2021-05-07 12:07:43|  0.3| 0.0|INFORM|Creating reader for format:
2021-05-07 12:07:43|  0.3| 0.0|INFORM|MULTI_READER(MULTI_READER): Will fail with first member reader failure
2021-05-07 12:07:43|  0.3| 0.0|INFORM|Using Multi Reader with keyword `MULTI_READER' to read multiple datasets
2021-05-07 12:07:43|  0.3| 0.0|INFORM|Loaded module 'Geometry_func' from file 'C:\\FME\\FME-2020\\plugins/Geometry_func.dll'
2021-05-07 12:07:43|  0.3| 0.0|INFORM|FME API version of module 'Geometry_func' matches current internal version (3.8 20200115)
2021-05-07 12:07:43|  0.3| 0.0|INFORM|Loaded module 'LogCount_func' from file 'C:\\FME\\FME-2020\\plugins/LogCount_func.dll'
2021-05-07 12:07:43|  0.3| 0.0|INFORM|FME API version of module 'LogCount_func' matches current internal version (3.8 20200115)
2021-05-07 12:07:43|  0.3| 0.0|INFORM|Loaded module 'XSLTFactory' from file 'C:\\FME\\FME-2020\\plugins/XSLTFactory.dll'
2021-05-07 12:07:43|  0.3| 0.0|INFORM|FME API version of module 'XSLTFactory' matches current internal version (3.8 20200115)
2021-05-07 12:07:43|  0.3| 0.0|INFORM| (XSLTFactory): Successfully initialized.
2021-05-07 12:07:43|  0.3| 0.0|INFORM|Loaded module 'InspectorFactory' from file 'C:\\FME\\FME-2020\\plugins/InspectorFactory.dll'
2021-05-07 12:07:43|  0.3| 0.0|INFORM|FME API version of module 'InspectorFactory' matches current internal version (3.8 20200115)
2021-05-07 12:07:43|  0.3| 0.0|INFORM|Emptying factory pipeline
Be the first to reply!
