Hi
There seems to be some problems regarding the Microsoft SharePoint List reader accessing SharePoint Lists when there is 2FA activated.
Using FME 2020.1.1 Build 20608 the connector returns a Azure AD error AADSTS70011.
Using FME 2019.2.2.0 Build 19817 returns this error: Failed to retrieve feature types.
Microsoft SharePoint List Reader: Error authenticating via SAML. Verify that the username and password are correct, and that this is a SharePoint Online instance. Response message was: '200'
The log file:
Creating reader for format: Microsoft SharePoint List
Trying to find a PYTHON plugin for reader named `SHAREPOINT'
Loaded Python module `sharepoint' from file `C:\Program Files\FME2019\python\python37\sharepoint\__init__.pyc'
Microsoft SharePoint List Reader: Items Per Request format parameter is set to '5000'
Microsoft SharePoint List Reader: Logging into 'https://geonett.sharepoint.com/sites/Support' as 'birk.slipersaeter@geodata.no' using authentication mode 'SAML'
Microsoft SharePoint List Reader: SSL certificate verification failed for host 'geonett.sharepoint.com'. HTTPS connections may not be secure. Disabling verification of SSL certificates. Message: HTTPSConnectionPool(host='geonett.sharepoint.com', port=443): Max retries exceeded with url: /sites/Support (Caused by SSLError(SSLCertVerificationError(1, '[SSL: CERTIFICATE_VERIFY_FAILED] certificate verify failed: self signed certificate in certificate chain (_ssl.c:1051)')))
Failed to obtain any schemas from reader 'SHAREPOINT' from 1 datasets. This may be due to invalid datasets or format accessibility issues due to licensing, dependencies, or module loading. See logfile for more information
UniversalReader -- readSchema resulted in 0 schema features being returned
Reader Parameter(0) = >https://geonett.sharepoint.com/sites/Support<
Reader Parameter(1) = >USER<
Reader Parameter(2) = >birk.slipersaeter@geodata.no<
Reader Parameter(3) = >PASSWORD<
Reader Parameter(4) = >********<
Reader Parameter(5) = >AUTHENTICATION<
Reader Parameter(6) = >SAML<
Reader Parameter(7) = >HIDDEN_LISTS<
Reader Parameter(8) = >No<
Reader Parameter(9) = >ALL_FIELDS<
Reader Parameter(10) = >No<
Reader Parameter(11) = >_MERGE_SCHEMAS<
Reader Parameter(12) = >YES<
Reader Parameter(13) = >RETRIEVE_ALL_TABLE_NAMES<
Reader Parameter(14) = >YES<
Reader Directive(0) = >RUNTIME_MACROS<
Reader Directive(1) = >USER,birk.slipersaeter@geodata.no,PASSWORD,********,AUTHENTICATION,SAML,HIDDEN_LISTS,No,ALL_FIELDS,No,_MERGE_SCHEMAS,YES,RETRIEVE_ALL_TABLE_NAMES,YES<
After turning off 2FA for a new user, it worked in FME 2019.2.2, but not FME 2020.1.1. Is it possible to access the SharePoint lists without deactivating the 2FA?
Kind regards,
Birk
