Get the direction of a polyline
  • November 16, 2022
  • 5 replies
  • 30 views
nelson
Participant
Hello,
Is there a transfomer to know the direction a polyline was drawn (forward or backward) ?
Thank you
Best answer by tcrossman
tomfriedl wrote:
This is a polyline:
_______________________________
What means here forward or backward?
Maybe first vertex = start, last vertex = end, and direction = start to end?
Use CoordinateExtractor to get _indices{} list attribute added to feature and then access the first and last coordinates as _incices{0} and _indices{-1}
tomfriedl
Forum|alt.badge.img+13
  • November 16, 2022
This is a polyline:
tcrossman
  • November 16, 2022
tomfriedl wrote:
This is a polyline:
nelson
Participant
  • Participant
  • November 17, 2022
tomfriedl wrote:
This is a polyline:
I'm working on wast water, a web application needs to know the network flow orientation in order to define symboly for the layer.
nelson
Participant
  • Participant
  • November 17, 2022
Thank you I'll see
hkingsbury
Forum|alt.badge.img+51
  • November 17, 2022
