Getting duplicate features when writing to ArcGIS Online
When writing to a hosted feature layer in ArcGIS Online we are getting duplicate features on occasion. In the latest run where this happened, there were 15,304 features in the dataset which were reported as written to ArcGIS Online, although the feature layer actually had 16,304 features written to it. Features with OBJECTID 9001 through 10000 were exactly duplicated making it seem like a batch of 1,000 features were written exactly twice during the process. OBJECTID 10001 was an exact duplicate of 9001, 10002 was a dupe of 9002 and so on.... After this batch of duplicates, subsequent features were not duplicated (features before OBJECTID 9001 were also not duplicated).
Best answer by mattmatsafe
Hi @gis_mapper​ and others encountering this issue:
FME Form 2023 (formerly Desktop) has introduced an Asynchronous Writes option to the advanced parameters of the ArcGIS Online Feature Server Writer. Setting this option to Yes should help resolve this issue.
Documentation can be found here: https://docs.safe.com/fme/2023.0/html/FME-Form-Documentation/FME-ReadersWriters/arcgisonlinefeatures/arcgisonlinefeatures_writer.htm
laurawatsafe
Forum|alt.badge.img+11
Hi @jasonschroeder​ , I hope you don't mind, but I'm going to escalate your question to a support case here. We'd like to dive into this a little deeper to get a clear picture of what might be causing this behaviour.
  • February 23, 2021
Has there been any resolution on this issue? We've seen similar behavior, but were not able to determine if the base table was not completely truncated, or duplicated rows were being written.
  • February 23, 2021
@dnfox​ The problem seems to be related to how the Feature Services writer handles retries. If there is any connection break during the data load, a retry is attempted and this can cause duplicate features. If a batch of data is uploaded, but the response either times out or returns an error, the writer will retry sending the same data again. This is supposed to only happen if the batch completely fails to be uploaded, but it seems like it can happen even when all the data was successfully uploaded and the writer doesn't receive a response from the server. Try reducing the Features per Request on the writer Advanced Parameters
@Mark Stoakes​ @dnfox​ - an FYI, I was still experiencing the duplicate issues even though I reduced the "Features per Request" to 250 at a time. It seems to me more about an Internet hiccup (response gets lost) than the number of features being sent.
ssharp
Participant
  • Participant
  • February 24, 2021
@Mark Stoakes​ Has a BUG# been assigned to this issue by Esri and/or Safe Software? Are there any efforts on the part of Esri and/or Safe Software to address this?
  • February 26, 2021
@ssharp​ Yes we are talking with our colleagues at Esri to try and find a resolution to this problem.
ssharp
Participant
  • Participant
  • March 1, 2021
Thanks for the reply @Mark Stoakes​. Do you have a Safe or Esri BUG# we can use to track progress AND receive notification once resolved?
bruceharold
Forum|alt.badge.img+17
  • March 8, 2021
Here is something we found effective while we're waiting for the underlying issue to be addressed. If your workflow is a truncate and bulk insert of all records regardless of whether rows are unchanged, instead additionally read in all target feature service features, perform a change detection and then only write inserts, updates and deletes. Make the features per transaction small too, say 100. This will help with what we think is an underlying timeout issue.
ssharp
Participant
  • Participant
  • March 8, 2021
@bruceharold​ thanks for the suggestion. Will this work if the target FS and source data lack unique stable IDs?
bruceharold
  • March 8, 2021
Yes, use a set of attributes to detect changes, except any floating point data like Shape_length where you can use the actual geometry. It may take some trial and error if your data are coming from differing systems of record for example by rounding coordinates to 6 decimal places, standardizing datetime fields and so on. Preserve ObjectID on updates and deletes from the target features so the service can match records. If you have no match key fields you will not have any updates, only inserts and deletes (logical updates are delete/insert pairs).
ssharp
Participant
  • Participant
  • March 8, 2021
Ok, sounds like a reasonable amount of time/effort would be required to develop/debug/test and roll this "workaround" into a production especially if stable ObjectIDs are not an option.
Has Esri and/or Safe Software recognized the underlying problem as a bug yet?
bruceharold
  • March 8, 2021
Not yet.
ssharp
Participant
  • Participant
  • March 8, 2021
jovitaatsafe
Hi @ssharp​ and @bruceharold​,
It looks like Mark had filed an issue for us on the Safe Software side tracked internally as (FMEENGINE-68673) and our team will be reaching out to Esri's development team on it to work together towards a solution.
bruceharold
  • March 9, 2021
Great, thanks Jovita.
ssharp
Participant
  • Participant
  • March 9, 2021
@jovitaatsafe​  thank you for confirming that Safe Software is working on this bug. Hopefully Esri will respond to your team's efforts.
I logged this as a case with Esri on 3/5/2021 (#02755502).
ssharp
Participant
  • Participant
  • September 3, 2021
@jovitaatsafe​ have Safe Software and Esri been able to make any headway regarding the logged FMEENGINE-68673 bug?
jovitaatsafe
Hi @ssharp​, unfortunately there isn't a resolution on the issue just yet. I'll add a note in the ticket to bring it to the team's attention and hopefully bump the ticket. I see you've got a case attached to the issue so you'll be informed there as soon as it's been addressed and updated here in this thread as well.
bruceharold
  • September 7, 2021
Here is another option, a pattern you can use to do bulk appends (prior truncation optional) https://community.esri.com/t5/arcgis-data-interoperability-blog/building-a-data-driven-organization-part-4/ba-p/1086265
ssharp
Participant
  • Participant
  • September 8, 2021
Thanks for the reply @bruceharold​  and @jovitaatsafe​
Was this ever resolved? We are having the same issue.
daraghatsafe
Hi @achamber_ak
Unfortunately it has not been resolved just yet, I have added your comment to the issue and when the issue is resolved we will be sure to let you know on this thread. Apologies for any inconvenience caused.
Hi - is there any more progress on this and has it been registered as a bug?
ssharp
Participant
  • Participant
  • November 23, 2021
No action on the part of Safe Software or Esri to the best of my knowledge to date....
https://support.esri.com/en/bugs/nimbus/QlVHLTAwMDEzODE2Mw==
  • November 24, 2021
@jasonschroeder​  @bruceharold​ @ssharp​ @dnfox​
FME 2021.1 and higher has improved logging that might help us trace the cause of this issue. Turn on the debug logging under the Tools menu -> FME Options -> Translation -> Log Message disclosure panel and check Log Debug. If you can send us a log file from a job that results in duplicates that might help us get this resolved. You can post the log file here or send it directly to me mark @ safe.com
