Featuretypefilter not recognising feature types
umapper1
Forum|alt.badge.img+5
Hi community,
I've gone back in to an old workspace and updated a feature reader transformer. It's then supposed to route into a Featuretypefilter to get a list of the feature types. Doesn't appear to be getting any results when I press 'update' in the Featuretypefilter transformer. Is this a bug or am I missing something here? See screenshots below. Am using ver 2020.1.FeaturetypeswantedFeaturetypesmissing
Best answer by virtualcitymatt
Hi @umapper1​ ,
This is because you are merging all your inputs (i think). One way is to actually use an AttributeFilter and use the "Import..." wizard to import the fme_feature_type values.
virtualcitymatt
Forum|alt.badge.img+35
Hi @umapper1​ ,
umapper1
  • August 4, 2020
Thanks @virtualcitymatt​ . Yes, think you're right there. I just thought that I had it that way before and still had the feature types coming through. It's not very practical to have 500 reader transformers pop up if I have 500 layers in the drawing. Thanks for the alternative though, that may suffice.
